Clears the Network Address Translation (NAT) VLAN counters.
| ip | Specifies Internet Protocol (IP). |
| nat | Specifies NAT. |
| vlan | Specifies VLAN NAT. |
| counters | Specifies NAT VLAN counters. |
| vlan_name | Specifies which VLAN to clear NAT counters for. If no VLAN name is specified, all counters are cleared. |
N/A.
To view counter information, run the command show ip nat vlan counters {vlan_name}.
The following example clears all NAT VLAN counters:
# clear ip nat counters vlan
This command was first available in ExtremeXOS 31.2.
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.1.1 Licensing Guide document.
